RT-AX86U: bug with guest network intranet access
David Arnstein
Most of the time, I have intranet access turned off. I needed it to be on today, and I changed it in the web GUI. Nothing changed. After I rebooted the router, intranet access was in effect.
Are you talking about the Guest network? Did you first try to disconnect and then reconnect with the client device in question?
Quite possibly a bug. email Asus customer support as they're unlikely to see your post here.
