austenpowers
I have a very minor question that relates to a cosmetic issue only... but I'll throw it out there anyway (and share what I've learned - by accident)...
So, I have learned for some client devices that if you open the device settings and look at the top-left corner where the client icon is displayed, if you click on "Default" your icon will actually change to the custom vendor-specific icon (which can be found in a file called "vender-list.png" which is stored on your router in the directory path below)...
[email protected]:/tmp/home/root# cd /www/images/New_ui/networkmap/
[email protected]:/www/images/New_ui/networkmap# pwd
[email protected]:/www/images/New_ui/networkmap# ls -lhtr vender-list*
-rw-rw-r-- 1 admin root 12.5K Jan 1 14:26 vender-listover.png
-rw-rw-r-- 1 admin root 12.2K Jan 1 14:26 vender-list.png
For example...
If you notice the image above, I clicked on "Default" and the custom Samsung icon appeared. I believe this happened because the "Device" is labelled "Samsung".
However, I have another Samsung TV where this did not work. For example...
As you can see, in this case the Device label reads "SmartTV", so when I click on "Default" nothing changes.
So my question: is there a way in which I can modify the "Device" label for my clients so that I can change icons to the custom vendor-specific icons?
I'm really knit-picking here and it's no big deal, but if someone knows how to do it, I'd appreciate some advice/direction.
Tks,
Todd
For example...
Tks,
Todd
