I have a specific configuration i want to achieve... here's the rundown.
I have a Modem at home Like a Comcast Xfinity X1 that my ISP provides for my TV Setup Box to work... this Modem is my cable modem but also a router, but i do NOT use this router for my home network, only as the MODEM and as the Xfinity comcast boxes.
I plugged in my Asus RT-AX86U in the Comcast Router/Modem in order to use my Asus router at home, instead of the poor router... and everything works.
My Xfinity Router LAN is setup on 10.0.0.x subnet and the router gateway IP is 10.0.0.1. All my Comcast TV boxes are using the Wifi of that Xfinity Router to work, so i would imagine they are all using 10.0.0.x IP's like 10.0.0.2, 10.0.0.3... etc...
My Asus router is plugged in one of the 4 ethernet ports in that Xfinity Router, and the WAN port of my Asus Router. So the WAN port of the Asus router picks up an IP from the Xfinity router, like 10.0.0.4.
All works, here...
My Asus router subnet is 192.168.0.x and the router itself is 192.168.0.1.
I setup an OpenVPN server on my Asus router, i can connect with my OpenVPN client from the internet... so far, this is expected. The subnet of the OpenVPN Server that is on my Asus Router is 10.16.0.x.
Now, from home, when i am on any computer that uses the Asus Router, i can access both subnets, the 192.168.0.x subnet of my router, and also the 10.0.0.x subnet for the Xfinity TV Setup boxes...
When i am remote, and i connect to my OpenVPN server, i can access any of the IP i have on my Asus Router, which is the 192.168.0.x subnet, through the openvpn vpn ip (10.16.0.3) for example as i am connected now.
But when i am connected, i can only access the 192.168.0.x subnet. I would like to also be able to connect to the 10.0.0.x subnet... but i lack the knowledge to understand if i need to configure this in the OpenVPN client, or on the OpenVPN server.
I would think it needs to be on the OpenVPN Server, but i have no idea what is needed...
Can anyone help guide me in the right direction?
All works, here...
