RoadRunnerTR21
I have been involved with database administration for 45 years. Mostly mainframe (DB2 and IMS) and Oracle on Linux server. I am not a network person by trade but I can get the basics done. I am also NOT a gammer. That said, my work environment consists of a Arris SB6183 modem connection to the internet. My RT-AX86U router connects to the Arris modem. I have 2 PC's hard wired to the router and several wireless devices as well. This configuration has always worked well for me with what I do. However, last week I ran into a situation that my network contacts cannot solve. I believe I have isolated the issue as being the router which is why I am here.
The issue:
Normally, I can run a stored procedure on a mainframe using a Windows client side product called IBM Data Studio. Once I start data studio, I issue a connection to a mainframe's IP address and then run my SQL statements, stored procedures, etc.. That process works great with or without the router. The problem occurs when I try to run the stored procedure in debug mode. In debug mode, data studio starts something called session manager on the Windows client machine. Before debugging starts, the mainframe tries to ping the session manager IP address to verify it is there and that's when things fail. This ping process times out because the mainframe can't ping the session manger IP address using the designated port which is 4553.
While trying to troubleshoot the problem, I tried connecting my client machine directly to the modem. When I ran debug mode, the process worked correctly.
Modem IP is 43.223.xxx.xx
Client machine IP is 192.168.56.1
The mainframe was pinging 192.168.56.1:4553
This process fails when the router is in the mix.
Router IP is 192.168.50.188
The mainframe was pinging 192.168.56.1:4553 and it failed to connect
When I contacted my network guy for some help, he suggested port forwarding. So I went to Virtual Server/Port Forwarding under WAN and added 192.168.56.1 for internal IP address, TCP for protocol and 4553 for external port and applied the changes. That did not work. My network guy also suggested turning on UPnP and ICMP but that did not fix the issue.
What can I do to try and remedy this situation?
The issue:
