RT-AX86U-Pro / RT-AX88U-Pro Speedtest question
NoLight
If you have:
  1. RT-AX86U-Pro or RT-AX88U-Pro
  2. Symmetrical 2g/2g or higher internet plan
  3. Connected to the 2.5gb WAN port
  4. Running stock
Have you seen the built in Ookla Speedtest max out the provisioned DL & UL speeds, up to the physical limit if higher then 2.5gb?
Thanks!
