RT-AX86U Stock Or Merlins?
RT-AX86U AP Stock Or Merlin Firmware
  • Stock
    Votes: 3 33.3%
  • Merlin
    Votes: 6 66.7%
  • Other
    Votes: 0 0.0%
  • Total voters
    9
Wolfclaw
As I use an OPNsense PC as my firewall/router and the RT-AX86U is now just an dual band AP connected using the 2.5G NIC, thought I'd ask for members thoughts and maybe why?
Nothing fancy needed for an AP. Keep it on stock for simplicity.
What is your use case for the RT-AX86U? If you don't need the extra features, options, and updates Asus-Merlin provides (or if they are not available in AP mode) then stick with stock firmware.
Asuswrt-Merlin because you can make it VLAN aware with custom script. Otherwise can’t have even proper Guest Network on it.
The script thread and for exactly the same model router. The OP made it Plug-and-Play.
