Hello, I currently have an AX88U as my main router which is upstairs in a corner of my house (living room media center) that has 7 devices on LAN and 1 port going to my basement as a backhaul to an AC88U. I am wanting to replace the AC88U with an AX router, so I’ve been considering getting an 86U and using it as the router since I’ve read that that results in the best latency. I only have 1 device on LAN on my basement node, but can easily pull a new cable from my fiber box to that downstairs spot.
So I am wondering if making my router the basement then having my node with all its devices attached will result in the same WAN latency, as those are the devices I care most about (2 PS5s 2 desktop computers Apple TV etc).
If that won’t work then I assume I’d need to have the 86U upstairs but then add a switch on the 2.5G port?
btw currently on stock firmware but will flash Merlin to the 86U and then also to the 88U node if that’s worth doing.
thanks
thanks
