RT-AX88U - Lost all web gui access for both mobile and PC
goldbondx
Hello, I have read a number of threads with related concerns with Asus. I just switched back to a Asus after 4 years of hell with ORBI and not completely used to UI.
I was running all great when I decided to make a few changes:
Changed my web admin access to HTTPS from both HTTP and HTTPS. I also turned on HTTP logging for S&Giggles..
I can no longer access the router admin gui via either the mobile client or multiple connected PC's. All I see on the PC is "ERR_CONNECTION_REFUSED". I would like to avoid doing a hard reset like some suggested on older models/threads.
Appreciate the help.
HI Colin, Apologies as I should have listed that. I tried the secured login from multiple PC's without success. I just restarted the unit (which I hadn't previously) and now secured seems to work on PC only. Can you confirm why the mobile app still does not connect? I am hoping this doesn't occur again on PC.
Uninstalled app and reinstalled. Selected secured login ONLY and I seem to be connected. Not exactly user friendly but back in business.
