Hi, I have this problem in my router RT-AX88u.
On the system status page, wireless MAC address are equal for 2.4 ghz to 5 ghz.
So basically the router doesn't work properly for the wireless part.
If I search for wireless networks with netspot I only see the 2.4 ghz network.
I have already tried doing hardware resets several times.
I installed Asuswrt-Merlin firmware which did not fix the problem.
Have you any suggest?
Thanks a lot
Thanks a lot
