I own two ASUS RT-AX88U devices.
One, downstairs, is configured to be my Router
One, on the top floor of my house, is configured to be an AIMesh node connected by wire to this router
When I first set up the AIMesh node I could connect to both the router and the AIMesh node, using AX 160 MHz bandwidth.
I have sinds then always updated it with the latest Merlin firmware available.
When I scan my WiFi networks both Router and AIMesh are visible.
Comparing the router and AiMesh broadcast,
I find three tagged parameters in the Router broadcast that are missing in the AiMesh SSID broadcast:
1 - Advertisement protocol -> "ANQP"
2 - Operation mode notification -> "Channel Width 80 Mhz, Rx NSS: 3Nss, RxNSS type 0x0"
3 - Vendor specific -> "Wi-Fi Alliance"
My phone connects to both the Router and the AIMesh node fine using AC and WPA2.
But my AX devices (Laptop with Intel AX200 and Intel NUC with AX201 using latest Intel drivers 21.80.2) both do no longer connect to the AIMesh node.
Using these devices, I can see the AIMesh node but when I want to connect, they both report "Cannot connect to this network".
I have tried setting both AX adapters to use AC instead of AX, but they still will not connect to the AIMesh node.
But downstairs they connect fine to the Router, with excellent speeds.
I assume the node has the same settings passed on as the router.
Therefor it is a puzzel to me why my AX devices no longer connect to the AIMesh node but my phone still does.
At this point they both are on firmware 384.18_alpha1, but I reverted to 384.15 - 384.16 and 3.84.17 and that did not solve the connection issue I am facing.
