RT-AX88U OpenVPN Custom Configuration GUI space issue
Rooby
Hello
I have upgraded from RT-AC88U to RT-AX88U but now I could not copy all my OpenVPN custom configuration settings into the GUI of the RT-AX88U. There seems to be not enough space availiable in the field compared to the RT-AC88U. I cannot paste all my pushes and iroutes there. Is there a space limition or maybe a bug? In the RT-AC88U it was possible.
Hello
see this post#
Use the appropriate .postconf script instead.
Thanks then I will use openvpnserver1.postconf script but can someone help me how can I add several lines e.g.:
push "route 10.10.2.0 255.255.255.0"
push "route 10.10.3.0 255.255.255.0"
push "route 10.10.4.0 255.255.255.0"
push "route 10.10.5.0 255.255.255.0"
route 10.10.6.0 255.255.255.0
If I want to use the /usr/sbin/helper.sh helper script do I need the pc_append for each line or is there a pssobility to add several lines?
You may find that this format is easier (assumes of course that the directives don't already appear in $CONFIG)
#!/bin/sh
CONFIG=$1
echo 'push "route 10.10.2.0 255.255.255.0"'
echo 'push "route 10.10.3.0 255.255.255.0"'
echo 'push "route 10.10.4.0 255.255.255.0"'
echo 'push "route 10.10.5.0 255.255.255.0"'
echo 'route 10.10.2.0 255.255.255.0'
echo 'route 10.10.3.0 255.255.255.0'
echo 'route 10.10.4.0 255.255.255.0'
echo 'route 10.10.5.0 255.255.255.0'
echo 'route 10.10.6.0 255.255.255.0' ) >> $CONFIG
vs.
pc_append 'push "route 10.10.2.0 255.255.255.0"' $CONFIG
pc_append 'push "route 10.10.3.0 255.255.255.0"' $CONFIG
etc.
A heredoc might be easier.
cat <<- EOF >> "$CONFIG"
EOF
Hello
I experienced this same issue last night it seems to have a limit of 500 and some odd characters.
#!/bin/sh
CONFIG=$1
vs.
etc.
this is the best solution.
