RT-AX88U Pro (3006.102.4) Wireless Settings Changes Not Saving – Apply Button Broken
Cico75
Hi everyone,
I'm experiencing a strange issue with the web GUI in the Wireless Settings.
Whenever I change something, I can't click "Apply" — nothing happens at all.
I've tried several browsers, but the problem persists.
Is there any known solution?
Regards
Setup: AX88U + 2x AX92U as Mesh
Is this a new install?
Have you tried the basic troubleshooting?
Factory reset --> flash firmware --> factory reset --> manual configure
Hi everyone,
Regards
Can you remove relese tag as you don"t relese anything. Tnks
After updating to the new firmware i made as usual a Factory reset to configure my settings manually.
I did this twice, didn't help.
Your mentioned order i did not do.
It seems that only this Page is not woking properly. Aplly Button does not work.
i have perfomance Problems when i leave the frequency's like this, i want to set to 20 and 80 as one value.
Is that screenshot from after your factory reset and without any changes? As 160 MHz and DFS channels are enabled your reset method is not working. Do the reset via Administration>Restore/Save/Upload Setting making sure that "Initialize all the settings" is selected.
Thanks...
I will do it via Adminstration, and try again.
I thoug reset via button is the same.
Thanks...
Valid for all asus routers wifi 5 and above.
I have one more piece of information.
I performed a factory reset (including clearing data) on all devices — both the router and the nodes. Then I manually configured the router from scratch using my preferred settings. Everything was working fine, and the 5GHz Wi-Fi was set to 80 MHz only.
After that, I added the first mesh node. As soon as it connected, the setting automatically
(the checkbox was ticked for 160 MHz), even though it still showed "80 MHz only."
From that moment on, I couldn't make any changes on this page — the Apply button no longer responds.
At least i have now the setting i wanted, but still the Aplly button does not respond.
Regards.
