Release RT-AX88U Pro Firmware Version 3.0.0.6.102_37421 (2026/03/24)
wol-shiver
ASUS RT-AX88U Pro Firmware version 3.0.0.6.102_37421
Version 3.0.0.6.102_37421 59.15 MB 2026/03/24
https://www.asus.com/supportonly/rt-ax88u pro/helpdesk_bios/
Bug Fixes and Enhancements
- Improved WiFi roaming behavior to reduce temporary disconnections in some scenarios.
- Improved roaming compatibility for certain client devices.
- Improved App Remote Connection stability in certain scenarios to prevent unexpected connection drops.
- Improved AiMesh onboarding reliability, addressing cases where the onboarding process could stall and fail to complete.
- Fixed an issue where the guest network client list might not display correctly in certain scenarios.
- Fixed an issue with Web history display.
- Fixed an issue where the app could not remove offline devices.
- Fixed an issue where specific IPv6 configuration flows could cause IPv6 connectivity problems on the main network.
- Fixed an issue where enabling System Diagnostics and staying on a specific page could cause repeated reboots.
Security Fixes
- Enhanced input validation and protection to reduce the risk of command injection and SQL injection.
- Hardened environment variable handling.
- Hardened protections around specific logging/command composition flows to reduce potential injection risks.
- Patched a command injection risk in a specific network diagnostic function.
We recommend upgrading to this version to maintain best protection.
Anyone know why this version is listed on the Asus support website, but a search for new firmware in the app and web GUI says no new firmware available?
Is it just a latency issue?
Situation normal, it often takes a few days for all of the company piece parts to get on the same page.
OK thanks. Seems like the query would check a config DB that would get updated in real time when a new version is uploaded.
But I guess I can do a manual update if I can’t wait. 😀
I recently installed beta Version:9.0.0.6.102_37342 which fixed guest network pro’s GUI missing dhcp reservation options. I’m foggy on it, but I think an update took it away over a year ago on mine. Back then I just jumped to Merlin, but I started using mesh nodes this month and wanted to see if stock firmware handled my devices better. I also really need reservations to tie down some flaky IOT devices with dns/firewall, and saw the feature not there to set. I reset to factory, rescue loaded, and nothing restored the GUI to manage them till the beta did. Again foggy on the details, maybe I confused if it should have ever been there.
Does anyone have the beta I’m on downloaded in case I want to try 3.0.0.6.102_37421 ? I got it automatically from the GUI and don’t want to screw up if it’s not offered to me later. Then again, maybe not touching things because everything seems to be working well now.
FWIW - The manual reservations are still in the AX86U Pro firmware _37421 so the should be in the same version for your AX88U Pro. Just do an upgrade from the beta and you shouldn't loose anything.
I’ll totally give it a go if I can get back to beta if needed. Anyway to backup your own firmware file?
