RT-AX88U rebooting on its own
mteicher
RT-AX8U is brand new with latest ASUS firmware. Only changes to to both 2.4GHz and 5GHz configuration:
MAC address filtering, accept
AX disabled
2 SSID, one for each channel
WPA2 personal, AES
I do not see anything in syslog indicating an issue.
Along with the reboots so far once a day and not at the same time syslog is quite busy with logging Auth, Assoc, Deauth. Wish there was a way to change syslog log level.
Insight, ideas are appreciated.
Michael...
2/14/2020 received replacement. Same hw ver a1.1 but built 2019 vs 2020. Upgraded to newest asus fw then did a hard reset. Keeping fingers crossed.
2/15/2020: 26 hours and no reboot. knock on wood so not to jinks it.
2/18/2020: Just shy of 4 days and no reboots. I will close this thread as it seems first router had issues and thus the reboots and purpose of my initial query.
If it randomly reboots and it's a new device, then I would first try to plug it in a different power outlet (in case there is a problem with it). If it still happens, then I recommend having it exchanged.
Hello RMerlin,
Its actually on the same surge protector as the replaced RT-AC87R. Its worth a shot tho and I appreciate your input.
Anyways what I did was call who I bought it from, Amazon, who first asked me to make sure the ethernet cable to the cable modem is seated good and the cable is in good condition. I said its new Cat5e. At that he said "let me get Asus on a conference call". Talked to Asus who wanted me to go through their "fire drill" at which I said the router is just a few days old. I balked at going through their fire drill stating my case, look at syslog I sent and changes etc.. He agreed and said to return it. In short Amazon was very pleasing and I will get replacement tomorrow. I just dont look forward to manually inputting all my mac address. I believe some things like that should be accepted as a txt upload.
Thank you...
