No, the main RT-AX88U router itself lost connectivity to the Internet but what is strange is the RED led status light is not lit up indicating the connection was lost.
Since changing the WAN settings on it to use Static IP instead of DHCP to connect to the cable modem the problem has not re-occurred.
So Internet disconnect is still happening with the WAN settings of the main RT-AX88U set to STATIC IP and ethernet port1 being used for the backhaul.
Oddly it's happened twice around the same time of the day, 9-10pm. Log file attached. Crash at 31:37
Oct 21 21:37:36 wlceventd: wlceventd_proc_event(511): wl0.1: Disassoc 62
6:0F:8D:47:8B, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Oct 21 21:37:36 kernel: dhd_prot_ioctl: status ret value is -30
Oct 21 21:37:36 kernel: CONSOLE: 127429.933 wl0.1: wlc_ampdu_flush_scb_tid flushing 0 packets for 62:d6:0f:8d:47:8b AID 19 tid 5
Oct 21 21:37:36 kernel: CONSOLE: 127429.966 iov:SCB_DEAUTH
Oct 21 21:37:37 kernel: CONSOLE: 127430.530 tx
rep:802.1x
Oct 21 21:37:37 kernel: dhd_flow_rings_delete_for_peer: ifindex 0
Oct 21 21:37:37 kernel: dhd_prot_flow_ring_delete: Send Flow Delete Req RING ID 197 for peer 00:07:a6:1e:87:b8 prio 5 ifindex 0
Oct 21 21:37:37 kernel: dhd_prot_flow_ring_delete_response_process: Flow Delete Response status = 0
Oct 21 21:37:37 wlceventd: wlceventd_proc_event(494): eth6: Deauth_ind 00:07:A6:1E:87:B8, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:-38
Oct 21 21:37:38 kernel: CONSOLE: 127431.525 iov:SCB_DEAUTH
Oct 21 21:37:38 kernel: CONSOLE: 127431.525 wl0.0: wlc_ampdu_flush_scb_tid flushing 0 packets for 00:07:a6:1e:87:b8 AID 17 tid 5
Oct 21 21:37:38 kernel: CONSOLE: 127431.546 iov:SCB_DEAUTH
Oct 21 21:37:38 kernel: CONSOLE: 127431.547 iov:SCB_DEAUTH
Oct 21 21:37:38 kernel: dhd_flow_rings_delete_for_peer: ifindex 0
Oct 21 21:37:38 wlceventd: wlceventd_proc_event(494): eth6: Deauth_ind 00:07:A6:1E:87:B8, status: 0, reason: Previous authentication no longer valid (2), rssi:-38
May 5 01:05:03 kernel: klogd started: BusyBox v1.24.1 (2022-09-19 14:26:47 CST)
May 5 01:05:03 kernel: Linux version 4.1.51 (
[email protected]) (gcc version 5.5.0 (Buildroot 2017.11.1) ) #4 SMP PREEMPT Mon Sep 19 16:02:30 CST 2022
May 5 01:05:03 kernel: CPU: AArch64 Processor [420f1000] revision 0
May 5 01:05:03 kernel: Kernel command line: coherent_pool=4M cpuidle_sysfs_switch pci=pcie_bus_safe rootwait
May 5 01:05:03 kernel: Virtual kernel memory layout:
May 5 01:05:03 kernel: vmalloc : 0xffffff8000000000 - 0xffffffbdffff0000 ( 247 GB)
May 5 01:05:03 kernel: vmemmap : 0xffffffbe00000000 - 0xffffffbfc0000000 ( 7 GB maximum)
May 5 01:05:03 kernel: 0xffffffbe00000000 - 0xffffffbe00e00000 ( 14 MB actual)
May 5 01:05:03 kernel: fixed : 0xffffffbffabfd000 - 0xffffffbffac00000 ( 12 KB)
May 5 01:05:03 kernel: PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
May 5 01:05:03 kernel: modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
May 5 01:05:03 kernel: memory : 0xffffffc000000000 - 0xffffffc040000000 ( 1024 MB)
May 5 01:05:03 kernel: .init : 0xffffffc0006be000 - 0xffffffc0006f7000 ( 228 KB)
May 5 01:05:03 kernel: .text : 0xffffffc000080000 - 0xffffffc0006bd204 ( 6389 KB)
May 5 01:05:03 kernel: .data : 0xffffffc0006f8000 - 0xffffffc0007c1f80 ( 808 KB)
May 5 01:05:03 kernel: init_timers: timer_function_timeout virt addr 0xffffffc000711388
May 5 01:05:03 kernel: creating mapping for reserved memory phys 0x0a600000 virt 0xffffffc00a600000 size 0x00e00000 for dhd0
May 5 01:05:03 kernel: creating mapping for reserved memory phys 0x09800000 virt 0xffffffc009800000 size 0x00e00000 for dhd1
May 5 01:05:03 kernel: creating mapping for reserved memory phys 0x08a00000 virt 0xffffffc008a00000 size 0x00e00000 for dhd2
May 5 01:05:03 kernel: Do not need to create mapping for reserved memory phys 0x0e000000 size 0x02000000 for buffer
May 5 01:05:03 kernel: creating mapping for reserved memory phys 0x0b400000 virt 0xffffffc00b400000 size 0x02c00000 for flow
May 5 01:05:03 kernel: pmc_init
MC using DQM mode
May 5 01:05:03 kernel: Successfully retrieved NVRAM data from dtb
May 5 01:05:03 kernel: cfe-v^A: 1.0.38-163.181
May 5 01:05:03 kernel: CPU1: Booted secondary processor
May 5 01:05:03 kernel: CPU2: Booted secondary processor
May 5 01:05:03 kernel: CPU3: Booted secondary processor
May 5 01:05:03 kernel: Broadcom Logger v0.1
May 5 01:05:03 kernel: skb_free_task created successfully with start budget 256
May 5 01:05:03 kernel: net_dev_init: process_backlog_timeout virt addr 0xffffffc0007b3f70
May 5 01:05:03 kernel: gbpm_do_work scheduled
May 5 01:05:03 kernel: ^[[0;34mBLOG v3.0 Initialized^[[0m
May 5 01:05:03 kernel: BLOG Rule v1.0 Initialized
May 5 01:05:03 kernel: Broadcom IQoS v1.0 initialized
May 5 01:05:03 kernel: Broadcom GBPM v0.1 initialized
May 5 01:05:03 kernel: >>>>> For primary mtd partition rootfs, cferam/vmlinux.lz mounted as JFFS2, vmlinux fs mounted as UBIFS <<<<<
May 5 01:05:03 kernel: Secondary mtd partition rootfs_update detected as JFFS2 for cferam/vmlinux source and UBIFS for vmlinux filesystem
May 5 01:05:03 kernel: setup_mtd_parts: misc indx 2 name misc3 nvram configured size 1
May 5 01:05:03 kernel: setup_mtd_parts: name misc3 configured size 0x00100000 offset 0xF600000
May 5 01:05:03 kernel: setup_mtd_parts: misc indx 1 name misc2 nvram configured size 63
May 5 01:05:03 kernel: setup_mtd_parts: name misc2 configured size 0x03f00000 offset 0xB700000
May 5 01:05:03 kernel: setup_mtd_parts: misc indx 0 name misc1 nvram configured size 8
May 5 01:05:03 kernel: setup_mtd_parts: name misc1 configured size 0x00800000 offset 0xAF00000
May 5 01:05:03 kernel: Creating 11 MTD partitions on "brcmnand.0":
May 5 01:05:03 kernel: 0x000005d40000-0x00000af00000 : "rootfs"
May 5 01:05:03 kernel: 0x000000640000-0x000005800000 : "rootfs_update"
May 5 01:05:03 kernel: 0x00000f700000-0x00000ff00000 : "data"
May 5 01:05:03 kernel: 0x000000000000-0x000000100000 : "nvram"
May 5 01:05:03 kernel: 0x000000100000-0x000005800000 : "image_update"
May 5 01:05:03 kernel: 0x000005800000-0x00000af00000 : "image"
May 5 01:05:03 kernel: 0x000005800000-0x000005d20000 : "bootfs"
May 5 01:05:03 kernel: 0x000000100000-0x000000620000 : "bootfs_update"
May 5 01:05:03 kernel: 0x00000f600000-0x00000f700000 : "misc3"
May 5 01:05:03 kernel: 0x00000b700000-0x00000f600000 : "misc2"
May 5 01:05:03 kernel: 0x00000af00000-0x00000b700000 : "misc1"
