1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Dismiss Notice
Welcome To SNBForums
RT-AX88U Setup Help Please
Discussion in 'ASUS AX Routers & Adapters' started by Col8eral, Apr 7, 2020.
  1. Col8eral
    Col8eral Regular Contributor
    Jan 26, 2017
    100
    I had a RT-AC88U that died recently. Just replaced it with a RT-AX88U.
    I have a broadband connection of at 200mbs
    When I connect laptop via ethernet to the AX88U I get the full 200mbs
    When using mobile phone via 5Ghz WiFi I get 60mbs even in the same room as the router. The same phone connected to my old AC88U I got the full 200mbs.
    The AX88U has he latest ASUS firmware but all other settings are at their default settings. Having said that all the settings on my old AC88U were default.
    Can anyone advise why the wifi performance on the new unit might be poor compared to the old one. Are their some settings you would advise I change so I can get the full 200mbs.
    Many thanks in advance.
  2. L&LD
    L&LD Part of the Furniture
    Dec 9, 2013
    13,042
    Consider using a new, never before used SSID. Or, test with either a Guest network or reset the client device (to forget the old network name), reboot it and then re-associate it again with the new router.
    I would also suggest the defaults of the M&M Config guide in the link in my signature below.
  3. dosborne
    dosborne Very Senior Member
    May 11, 2019
    606
    /dev/null
    You may want to share what your wifi settings are too.
  4. sanke1
    sanke1 Senior Member
    Jan 11, 2014
    326
    IN
    I hope you are using separate SSIDs for 2.4 Ghz and 5 Ghz networks. Number 1 source for all wifi speed complaints.
    Make sure you are using Channel 40 for 5Ghz Wifi. Enable AX and also enable 160 Channel Bandwidth. Rest of the settings to their defaults.
    Leave the Professional Tab settings to their default as well... the way they are after factory reset.
  5. Col8eral
    Jan 26, 2017
    100
    I have tried forgetting network on the client devices and then re-connecting but no joy.
    Both the networks are separated into two SSIDs
    I have enabled 160 channel bandwidth
    How do I share my settings? Is that a screen shot or can I download them somehow?
  6. sanke1
    Jan 11, 2014
    326
    IN
    Here are my settings. Rest all the settings are default under Professional Tab
    [​IMG]
    I am having zero wifi issues. My internet is 100 Mbps and I consistently get that speed on all my wireless devices.
  7. swejuggalo
    swejuggalo Regular Contributor
    Feb 5, 2019
    70
    Have you checked the link speed you get between router and phone? 192, 866, something in between or worse? Tried manual channels instead of Auto on 5Ghz?
  8. Val D.
    Val D. Very Senior Member
    Jun 16, 2019
    1,480
    What?
  9. Col8eral
    Jan 26, 2017
    100
    Been playing around with wireless settings and have seen some good improvement. Seems like I live in a busy WiFi area and lots of potential for interference.
    • Disabled universal beam forming
    • Disabled airtime fairness
    • Disabled mu Mimo
    • Set preamble type to short
    • Changed the control channels to manual
    • Set 160 for 5ghz
    For 2.4ghz and 5ghz this resulted in almost a trebbling of speed. I have a 200mbs broadband service and now at furthest distance from the router over WiFi I get 180mbs for 5ghz and 30mbs for 2.4ghz.
    I'd like to get the 2.4ghz performance a bit better. Any thoughts?
  10. Val D.
    Jun 16, 2019
    1,480
    How many 160MHz channel capable devices do you have?
  11. Col8eral
    Jan 26, 2017
    100
    Only one
  12. Val D.
    Jun 16, 2019
    1,480
    What device and what it is used for?
    Your full 200Mbps ISP speed is reachable with a simple 1x1 AC client on 80MHz channel.
    L&LD likes this.
  13. Col8eral
    Jan 26, 2017
    100
    I have a work laptop with an m.2 adapter. Only used for basic emails and growing though. Nothing strenuous.
  14. Val D.
    Jun 16, 2019
    1,480
    You don't need to occupy the entire WiFi spectrum with 160MHz channel then. 80MHz wide on the best throughput control channel in your area is more than enough for your needs.
  15. Col8eral
    Jan 26, 2017
    100
    I changed to 80mhz only and I say to say it's a little faster. Thank you.
    Any thoughts on improving 2.4ghz
  16. Val D.
    Jun 16, 2019
    1,480
    Your options are limited there. Some RT-AX88U users report 2.4GHz signal level reduction with newer firmwares, actually. Stick to 20MHz channel, disable all Roaming Assistant, Airtime Fairness, MU-MIMO, Beamforming, TX Bursting... and hope for the best. In urban areas 2.4GHz band is usually overcrowded and if you can push steady ~30Mbps it's already a good achievement.
  17. Col8eral
    Jan 26, 2017
    100
    Thanks. Seems like I'm doing ok then
