RT-AX88U vs RT-AC86U as a node?
CBR1000RR
Hi. Noticed a few people in other posts mentioning that they use a higher end router as a node. I was thinking of doing this but not sure if it would actually improve performance when connected to the node.
I have a RT-AX88U as my primary router and an RT-AC86U as a node. I average around 400mbps when connected to the AX88 and about 150mpbs when connected to the AC86. Would the speeds improve when connected to the node if I upgraded it to an AX88 or is there just a bottleneck somewhere that can't be avoided?
Not really a big deal either way but would like to improve node speed if I could. Do I need to get 400-500mpbs all over the house? Nah. Do I want it? Yeah. :p
In my house with 2 RT-AX88Us connected in mesh mode, I get 500-600 Mbps anywhere and in any room. I had RT-AC68U and Blue Cave before and just that they were not doing a good job of being in a mesh network because AX88U was AX and those were AC.
You also need to make sure that the November 2019 firmware for RT-AX88U is not used as it has speed problems with AC devices. Downgrade that to Version 3.0.0.4.384.6436
Rt ax 88 u? Expensive node
