tonydatillo
I just purchased a RT-AX88U to replace my RT-AC68U and switched my internet service to Xfinity Gigabit. When I use the either Asus router, my speedtests are very low any pc's that are connected to the lan ports on the router. At the moment, I can't get much more than 500 down. Sometimes it peaks in the 600's. When I use the Xfinity Gateway as my router, my pc's get between 900-950 down on speedtests. Running the latest Merlin firmware.
Anyone have advice on using the RT-AX88U and getting the proper wan to lan throughput? I've seen a few posts about this, but I haven't found a solution. The AX88U doesn't have NAT Acceleration to turn on. I have tested with Spanning Tree Protocol off and on. QOS was off by default and I never turned it on. Have tested with AiProtection off and on.
