RT-AX92U - How can I measure the router->node (backhaul) connection speed?
Gilad
Got the mesh system setup and tweaked the settings and wanted to test the master<->node connection speed.
I tried to ssh but there's no iPerf on neither one and apt-get/yum install seems to be unknown to the shell.
Any ideas/tips on how to measure the backhaul speed?
Thanks!
Gilad
Ok, found the solution:
SSH to the node and run:
iperf3 -s -D
Then SSH to the master and run:
iperf3 -c 192.168.1.249
Change the IP to the node IP of course :)
Smokey613
I just did this.... not sure how good my results are.
Connecting to host 192.168.2.2, port 5201
[ 4] local 192.168.2.1 port 55068 connected to 192.168.2.2 port 5201
[ ID] Interval Transfer Bandwidth Retr Cwnd
[ 4] 0.00-1.01 sec 28.3 MBytes 236 Mbits/sec 3 288 KBytes
[ 4] 1.01-2.00 sec 28.2 MBytes 237 Mbits/sec 1 253 KBytes
[ 4] 2.00-3.01 sec 28.9 MBytes 240 Mbits/sec 1 230 KBytes
[ 4] 3.01-4.01 sec 29.2 MBytes 246 Mbits/sec 0 310 KBytes
[ 4] 4.01-5.01 sec 29.0 MBytes 243 Mbits/sec 2 277 KBytes
[ 4] 5.01-6.00 sec 29.3 MBytes 249 Mbits/sec 0 348 KBytes
[ 4] 6.00-7.01 sec 29.5 MBytes 245 Mbits/sec 0 368 KBytes
[ 4] 7.01-8.01 sec 27.2 MBytes 227 Mbits/sec 14 281 KBytes
[ 4] 8.01-9.02 sec 25.5 MBytes 212 Mbits/sec 0 345 KBytes
[ 4] 9.02-10.01 sec 30.0 MBytes 253 Mbits/sec 0 368 KBytes
[ 4] 0.00-10.01 sec 285 MBytes 239 Mbits/sec 21 sender
[ 4] 0.00-10.01 sec 283 MBytes 237 Mbits/sec receiver
Gilad
Mine are a bit higher although on a AX exclusive back-haul (which I have as it's used only for this) , I would expect higher speeds.
I get:
Connecting to host 192.168.1.249, port 5201
[ 4] local 192.168.1.1 port 46880 connected to 192.168.1.249 port 5201
[ 4] 0.00-1.00 sec 66.1 MBytes 553 Mbits/sec 77 427 KBytes
[ 4] 1.00-2.01 sec 72.5 MBytes 606 Mbits/sec 7 387 KBytes
[ 4] 2.01-3.00 sec 72.7 MBytes 611 Mbits/sec 0 513 KBytes
[ 4] 3.00-4.00 sec 68.9 MBytes 578 Mbits/sec 89 238 KBytes
[ 4] 4.00-5.00 sec 56.6 MBytes 476 Mbits/sec 6 297 KBytes
[ 4] 5.00-6.00 sec 60.4 MBytes 506 Mbits/sec 17 365 KBytes
[ 4] 6.00-7.00 sec 67.0 MBytes 563 Mbits/sec 46 390 KBytes
[ 4] 7.00-8.00 sec 74.4 MBytes 622 Mbits/sec 0 518 KBytes
[ 4] 8.00-9.01 sec 73.6 MBytes 617 Mbits/sec 63 324 KBytes
[ 4] 9.01-10.00 sec 71.8 MBytes 603 Mbits/sec 0 467 KBytes
[ 4] 0.00-10.00 sec 684 MBytes 574 Mbits/sec 305 sender
[ 4] 0.00-10.00 sec 681 MBytes 571 Mbits/sec receiver
Gilad
So should we run
iperf3 -s (not as a deamon)
On the node and test from the master?
ugandy
So should we run
i think you should test between 2 clients connected to your nodes. or between client and wan
