Rt-ax92u
Samuel_1975
Rt-ax92u
it is not possible to block (adult sex) on the router and if I do it shuts down wifi and internet connection because remote control is also turned off
aiprotection does not work well to block porn for children and this should be fixed
AiProtection doesn't block porn without use of the correct settings. You need to use DNS services that help block adult content. You'll find a list within the routers GUI.
There are plenty of services available , none however will block 100% of problems as new sites come along every few minutes.
This is nonsense , you are not configuring the settings correctly.
I find it strange that aiprotection has parental control over blocking pornography and does not work
if you put words in the firewall that you want to block, it blocks the entire router to the internet and disables wifi to not connect to the internet
I'm fairly new to remote control of the internet by router and I think that remote control should not be turned off when trying to block what I wrote before,
I try to help my sister who lives 3 hours away from me by car so I have a hard time getting there and that is why I help her family to remote control and update
The firewall keyword list and AiProtectioin are entirely different things.
The page and settings you require are here :
AiProtection Family Settings.
To protect your sister she would be best setting up an account at OpenDns where you can choose all the category types you wish to block. All she then needs to do is add the OpenDns numbers into the router.
I tested with opendns now and I am visiting my sister so I have to help as my sister and her husband know nothing about routers and updating with programs updating mobiles and operating systems and more
thanks for the help and hope
from Samuel in Sweden
I wonder how I can get roblox.com white listed in opendns as I have tried to white list, well it stops some adult pages and it is good and one is crazy and looking for why websites do not work as I can see on the log in my sister's router, this's what my setting looks like
