I replaced a TUF AX6000 for RT-BE86U and noticed that when making speed test with wifi my ping is 2 ms higher than with TUF. Doing speed test in the router I get 2 ms, with TUF I would get 4 - 5 ms and with BE86U I get 6 - 7 ms. This is inexpected for me. Anyone with BE86U can share his experience?
I also have a BD4 as mesh node and I realized that if I create the wifi IoT network and after I try to add the BD4 it gives an error and doesn't join the mesh. If I add the BD4 and after create the IoT network, it works. Is this normal? I was also achieving higher speeds in the BD4 when using TUF AX6000 than with BE86U (900 vs 800 with wireless backhaul and ethernet fronthaul).
Thanks.
Thanks.
