RT-BE88U: IPv6 routing fails for LAN clients
JaneuX
I’m dealing with an IPv6 issue where addressing works, but routing from LAN
clients does not.
In short:
The router itself has full IPv6 connectivity, and all LAN clients receive valid
global IPv6 addresses and a default route, yet IPv6 traffic from LAN clients
does not reach the internet.
This looks like a case where IPv6 address assignment works correctly,
but IPv6 forwarding from LAN to WAN fails.
What I already checked / tried:
- ICMPv6 is allowed (RA, NS, NA, echo)
- IPv6 forwarding is enabled
- Firewall FORWARD chain allows br0 → WAN
- MTU tested (1500, lower values tested as well)
- WAN interface has a global IPv6 address
- Prefix delegation works
- Tried ISP DNS vs custom DNS (no change)
- Router and Modem Hardreset (nothing worked)
- Same behavior with passthrough AND native IPv6
Key observations:
- Router IPv6 connectivity works
- LAN clients receive global IPv6 addresses and have a default IPv6 route,
but IPv6 traffic from LAN clients does not reach external networks.
Has anyone encountered a similar situation or can help identify
what part of the IPv6 routing path is likely broken here?
Not an Ipv6 expert by any means.
What does the score on this site say?
https://test-ipv6.com/
PS: I don't use IPv6 so I get a zero score.
Hope this helps.
