Release RT-BE92U Firmware version 3.0.0.6_102_37548
Spartan
Just received this update via the ASUS Android app
Was just coming here to see if there was a thread for this. I'm going to update now.
Update: Been running with this firmware for a few hours now, and everything seems fine. Only slight issue is one of my smart bulbs was slow to reconnect, but that might just be an issue with the bulb as once it reconnected it's been fine. All other devices were ready to go. Sometimes I have to unlock my iPhone on a router reboot as well, as sometimes it doesn't auto connect either. With those two minor formalities out of the way, everything is working as it should.
What about MLO and full-strength 6Ghz?
I've explained a few times that currently I have no devices that can use MLO, so I have no need for the feature. I mainly bought this router for access to multiple 2.5 Gbps ports when I needed to take advantage of more bandwidth / speed. I bought this instead of a Wifi 6e router to save money going forward e.g. having to buy again whenever I got more WiFi 7 devices. This is something I can grow with now.
The second reason I got this, was for the newer features of AsusWRT that the RT-AX86U will never get, and again it made more sense to just buy a WiFi 7 router over something like the RT-AX86U Pro, to only have to buy once and be ready for any future needs that may come along.
I had a notification on my phone this morning from the Asus router app about new firmware. However, when checking in the web UI, it still says the version this thread is focused on, is still the latest one.
Edit: It's possible that it was referring to update for the RT-AX86U, but that router isn't plugged in, and active. It is connected to the Asus Router app though.
Edit #2: Was able to confirm after getting the push notification a second time that it was referring to the RT-AX86U update. I tapped got it, so hopefully it will stop nagging since I manually updated the router. I had forgotten the Asus Router apps notifies of firmware updates. Nice reminder.
These email notifications from Asus regarding Firmware updates are not always up to date. I just got an email for the RT-BE92U firmware update ending in 37504, and there is a newer version on the router. Mine ends in 37548 which is this firmware.
