RT-BE96u and older firmware downgrade
Jessop
I assume this has been discussed i promise i did try to search for the answer many ways LOL; but with ASUS blocking older firmware on the download site as well as blocking non-approved firmware from being installed, is there another way to install merlin?
What I've done so far is did the following:
• tried multiple times to install via the GUI
• Connected via ssh and ran these commands
nvram set DOWNGRADE_CHECK_PASS=1
nvram commit
• Reset to factory defaults multiple times as well as before and after committing the nvram settings
This brand new router is set to firmware: 3.0.0.6.102_37031 in case it helps any. I'm just looking for some steps / recommendations, or anything that can help me downgrade. I am upgrading from an RT-AC68P and i would love to just export the settings and import the settings after I get Merlin installed and not have to rebuild my entire mesh that consists of two other AC68p's in mesh mode on my property.
Now, I am also wondering if there isn't a Merlin that will work with this new router from Asus yet. I assume they are blocking everything due to all the Sev1 vulnerabilities that was found on older firmware recently, so they are protecting themselves to ensure they don't allow downgrading but thats just an assumption on my part and i obviously could be totally off base.
Thanks for any help or suggestions or recommendations if there is something i can do. If i just need to wait for a new way to install Merlin i can wait. Obviously if need be i could go back to asus's branded firmware and reconfigure my entire mesh. Though to be honest I'd rather merlin firmware as i've been running it for about 8 years and its just more intuitive LOL.
I can't really follow what you're asking.
Are you trying to install an older version of the stock 3.0.0.6.102 firmware (why?).
Are you trying to install Merlin's firmware (3006_102.6_0)?
Regarding the RT-AC68P, you shouldn't export settings from that and load them into the RT-BE96U. They're two completely different routers with different hardware and vastly different firmware.
Sorry I'm trying to go from asus's firmware to Merlin but no matter what I've tried I just can't get it to install.
Try installing ASUSwrt 3.0.0.6.102_38984 first...
I just did this, and surprised I didn't need to set modify NVRAM maybe a fluke maybe not.
Got the latest ASUS RT-BE96U Firmware version 3.0.0.6.102_39112 for the router, applied it.
After it came back up. Applied Merin 3006.102.6 over it, and after it rebooted and it succeeded. Working fine...
