RT-BE96U - Blocking WAN while maintaining LAN on Guest Network Pro/VLAN
vector01
Hi everyone I'm new here. Relatively new to home networking. I have a RT-BE96U running ASUS firmware version: 3.0.0.6.102_37849.
I have 3 Tapo/TP-Link Wi-Fi cameras on a guest network pro SSID/VLAN (not on main subnet). I want to be able to access via LAN, but I don't want them connected to Tapo's cloud/WAN. If I block their internet in the ASUS router app, they lose LAN connection. I have them on static IPs and tried to use Network Services Filter in the firewall settings, but it didn't work.
Can this be achieved with the ASUS firmware?
If not, I'm open to potentially exploring trying Merlin, but would like some guides on how to do it if there are any.
Do the cameras lose their local network connection... or, is a camera app no longer able to access the cameras because they are designed to be accessed by way of their Internet cloud account, locally or remotely from anywhere?
Are the camera static IPs assigned by the router, or by you manually on each camera?
OE
If you want the cameras to access the main LAN clients, why bother putting them onto a Guest Network? Why not just put them on the main LAN WiFi, then use the Parental Controls bock internet option (or Network Map, client block internet option).
Do a search of the Asus forums here and you'll find numerous people over several discussions having similar wishes/issues. Wanting to block WAN access to Guest Network Pro clients while having access to local network main LAN clients. The Guest Network Pro Access Intranet feature is hit or miss, either works or it it doesn't. Some are resorting to using iptables scripting in a firewall-start file to block WAN access to Guest Network Pro clients and also allowing access to local network LAN clients.
Some past discussions...
Example iptables scripting with a firewall-start file at this post:
https://www.snbforums.com/threads/t...st-network-pro-limitations.94438/#post-952345
One may have to do some experimenting ,and searching of this forum to find past script examples, to get things to work right for their use case.
To use a firewall-start script file one will need to move to using Asus-Merlin firmware. Some have gone back to the 3004.388.x firmware on their 3006.102.x firmware supported routers in order to regain usage of YazFi to accomplish the blocking of internet while allowing main LAN access for Guest Network clients. YazFi is not supported under 3006.102.x firmware.
