Rt-n18u sambaclient high cpu load
rivo
Hi!
I´ve an Asus rt-n18u + 380.59_HGG-FINAL.
I am very satisfied with the performance of this firmware that greatly improves the official firm.
The problem is the CPU load goes up to 100% (or almost) when mounted my USB HDD on the router.
Top command shows that the sambaclient process is the culprit
I have run a health scanner but the problem persists.
The file system is NTFS and I only use the disk for my backups. I tried to disable Smart Sync with the same result. The only thing that works is to remove the HDD.
Upnp media server and minidlna are disabled.
Somebody could help me?
Thank you in advance.
Sorry mate but what firmware are you running on your RT-N18U, i just checked and Merlin isnt compatible with that router type model
Hi!
What FW u run on the RT-N18U?
The latest hggomes (380.62) firmware is also available now.
TODO LIST:
- Ipset to 6.29 version.
- Iptables nDPI support.
- WEBUI wireless management restriction.
- WEBUI overclocking support.
CHANGES:
380.62: (2 OCT 16)*
- NEW: Kernel 2.6.36.4 (ARM SDK6/7/7.14) backports/fixes.
- NEW: LZMA compression on MIPS devices, saving ~400KB size on TRX file.
- NEW: Optimal wireless default settings.**
- NEW: Transmit Hash Policy option added to Link Aggregation (LACP).
- FIXED: AI Protection / Time Scheduling increased to 64.
- FIXED: Allow firmware downgrade via web interface.
- FIXED: Changing HTTP port option in WEBUI, has been broken since build 380.59.
- FIXED: Minor code issues.
- FIXED: RT-AC66U/RT-AC68U reboot loop when in repeater mode.
- FIXED: RT-AC68U 2-stream 802.11ac wrong entry.
- FIXED: WEBUI System administration page, SSH Daemon now hides all sub options when "No" is selected.
- FIXED: WEBUI Firmware Upgrade page code.
- FIXED: Wrong translation in HU dictionary "Zenekar" <-> "Frekvencia".
- UPDATED: Curl to 7.50.3 version.
- UPDATED: Neon to 0.30.2 version.
- UPDATED: Nettle to 3.3 version.
- UPDATED: NMap to 7.30 version.
- UPDATED: OpenSSL to 1.0.2j version.
- UPDATED: SQLite to 3.14.2 version.
- UPDATED: Tor to 0.2.8.8 version.
- UPDATED: Util-Linux to 2.28.2 version.
* IN ORDER TO FLASH NEWER ASUS STOCK/RMERLIN FW VERSIONS, A DOWNGRADE TO 380.59.1 OR LOWER VERSION IS REQUIRED.
** HW RESET/FACTORY DEFAULT AND MANUAL SETUP IS REQUIRED, DO NOT USE CONFIGURATION FILE IMPORT OR OLD SETTINGS WILL BE APPLIED AGAIN.
Safely unmounts the USB device(s) via the gui. Remove the USB devices. Reboot the router. Wait at least 5 minutes after rebooting so the router can settle.
Flash the latest firmware. Then follow the links below.
http://www.snbforums.com/threads/no...l-and-manual-configuration.27115/#post-205573
http://www.snbforums.com/threads/faq-nvram-and-factory-default-reset.22822/
http://www.snbforums.com/threads/rt-ac66u-slow-wan-to-lan.12973/page-3#post-269410
TODO LIST:
CHANGES:
380.62: (2 OCT 16)*
This looks really awesome, where can i get this latest firmware? any download links? :D
