RT-N56U 5Ghz fades under load
chaosmage
Hello all,
Im using RT-N56 on the latest firmware 3.0.3.8-081, and have set up 5Ghz channel for gaming only.
When i stream my screen to my laptop, i have very high ping times (up to 60sec)
99U5Al2j-jMFw2cXNm2hllXzw4JM5YOef6cdOkTB8Qc
And the connection fails. I even can't connect to the router from my phone with 5Ghz.
Bandwidth is always around 2-3MB and seems to be not the issue.
When i download huge files, the latency grows but not that much:
iB8iuZ9NnTCnuodnL0u48E8mZEZ8SEkkKZcEwsIb-sU
There is no CPU bottleneck as Load Avg is 0.01 all the time.
Log does not show any errors.
2.4Ghz works fine at the same time.
Here are the settings:
N96yuRJAdpAwEI1lIArvLkJRTMKvILWh4UkRxmFrag8
Do you know if there is any chance to trace this behaviour?
Any ideas? I am completely stuck
Regards,
ChaosMage
I'm also using Padavan's software, but with no problems. Check your wireless cfg for 5 GHz. Is it set for a/n, a only, or n only? Set it for n only and see if it improves.
