RT-N66 disable wireless & remote admin logon
How does one disable wireless & remote admin logon for an RT-N66?
If by remote you mean "from WAN", then it's not enabled by default.
Wifi login cannot be disabled.
One way to better control management is to switch from HTTP to HTTPS, use a different port than the default 8443, and possibly enable the function to only allow management from specific IPs (all configurable on the same Administration -> System config page).
Can't speak to the factory firmware or Merlin's but TomatoUSB from Shibby ( 1.28.0000 MIPSR2-121 K26 USB AIO-64K). has a page in the web interface dedicated to Administrative Access and wireless access can be turned off as well as remote administrative access. I have not tested it, just trust it works.:p
not sure about it but you should be able to disable radio by going
Wireless --> Professional --> (select frequency 2.4GHz or 5 GHz) --> Enable Radio
