As you use Merlin's firmware, you should post this question to the correct forum, but you can also look on your router's web interface under Tools (scroll down) to find the answer...I am running version 378.56_2 on my router RT-N66U.... Is is possible to see which of the 4 wired ports are connected and whether at 10 or 100 or 1000?
chief@RT-N66U:/tmp/home/root# robocfg show
Switch: enabled gigabit
Port 0: DOWN enabled stp: none vlan: 1 jumbo: off mac: 00:00:00:00:00:00
Port 1: DOWN enabled stp: none vlan: 1 jumbo: off mac: 00:00:00:00:00:00
Port 2: DOWN enabled stp: none vlan: 1 jumbo: off mac: 00:00:00:00:00:00
Port 3: 1000FD enabled stp: none vlan: 1 jumbo: off mac: 6c:3b:e5:xx:yy:zz
Port 4: DOWN enabled stp: none vlan: 1 jumbo: off mac: 00:00:00:00:00:00
Port 8: 1000FD enabled stp: none vlan: 1 jumbo: off mac: 08:60:6e:xx:yy:zz
VLANs: BCM53115 enabled mac_check mac_hash
1: vlan1: 0 1 2 3 4 8t
2: vlan2: 8t
Thanks for the quick reply. I will post further questions in the appropriate forum.As you use Merlin's firmware, you should post this question to the correct forum, but you can also look on your router's web interface under Tools (scroll down) to find the answer...
Or you connect via telnet/putty to the router and issue the command below:
Code:chief@RT-N66U:/tmp/home/root# robocfg show Switch: enabled gigabit Port 0: DOWN enabled stp: none vlan: 1 jumbo: off mac: 00:00:00:00:00:00 Port 1: DOWN enabled stp: none vlan: 1 jumbo: off mac: 00:00:00:00:00:00 Port 2: DOWN enabled stp: none vlan: 1 jumbo: off mac: 00:00:00:00:00:00 Port 3: 1000FD enabled stp: none vlan: 1 jumbo: off mac: 6c:3b:e5:xx:yy:zz Port 4: DOWN enabled stp: none vlan: 1 jumbo: off mac: 00:00:00:00:00:00 Port 8: 1000FD enabled stp: none vlan: 1 jumbo: off mac: 08:60:6e:xx:yy:zz VLANs: BCM53115 enabled mac_check mac_hash 1: vlan1: 0 1 2 3 4 8t 2: vlan2: 8t
With kind regards
Joe![]()
We use essential cookies to make this site work, and optional cookies to enhance your experience.
