RT-N66U and VPN on OS X
w0lver
I've tried search the threads here, the ASUS site and Google and I'm not find anything on how to configure OS X Lion to VPN into the RT-N66U. Now there are not may settings so I figured this was a no-brainer. No Joy! So I'm assuming its a PPTP connection. I have turned it on at the router, added a username and password, applied the settings. But in my hostname from DYNDNS, I have also tired just my current IP just in case, no perform identically.
It says connection, the icon does it thing then I get an error message that I've been "disconnected from the communication device."
Any ideas? I've updated to the latest firmware, in case it was a bug.
Oh here's the logs:
6/30/12 5:51:53.066 PM pppd: pppd 2.4.2 (Apple version 560.13) started by RossRankin, uid 501
6/30/12 5:52:01.431 PM pppd: PPTP connecting to server 'w0lver.homedns.org' (24.99.67.40)...
6/30/12 5:52:01.558 PM pppd: PPTP connection established.
6/30/12 5:52:01.563 PM pppd: Connect: ppp0 <--> socket[34:17]
6/30/12 5:52:31.579 PM pppd: LCP: timeout sending Config-Requests
6/30/12 5:52:31.580 PM pppd: Connection terminated.
6/30/12 5:52:31.590 PM pppd: PPTP disconnecting...
6/30/12 5:52:31.591 PM pppd: PPTP disconnected
6/30/12 5:52:52.705 PM configd: SCNC: start, triggered by System Preferen, type PPTP, status 0
6/30/12 5:52:52.716 PM pppd: pppd 2.4.2 (Apple version 560.13) started by RossRankin, uid 501
6/30/12 5:52:58.058 PM pppd: PPTP connecting to server 'w0lver.homedns.org' (24.99.67.40)...
6/30/12 5:52:58.219 PM pppd: PPTP connection established.
6/30/12 5:52:58.223 PM pppd: Connect: ppp0 <--> socket[34:17]
6/30/12 5:53:28.235 PM pppd: LCP: timeout sending Config-Requests
6/30/12 5:53:28.236 PM pppd: Connection terminated.
6/30/12 5:53:28.247 PM pppd: PPTP disconnecting...
6/30/12 5:53:28.248 PM pppd: PPTP disconnected
First off, just to make sure check your setup steps here,
How to set up a VPN connection on the Mac OSX in a wireless router: http://support.asus.com/Search/KDetail.aspx?SLanguage=en&no=0B982419-6249-9DCF-8BCC-D7127F1637E9&t=2
If you are trying to set the router up as a VPN server, you can follow the steps here,
How do you set up the ASUS wireless router as a VPN server: http://support.asus.com/Search/KDetail.aspx?SLanguage=en&no=39EB5311-E0CD-96D0-7B13-2C4F532929B4&t=2
*I know the router model is different, but the steps should be the same.
Also, make sure you are testing the VPN from outside your network, as otherwise it might have trouble doing a loopback from inside the LAN.
