RT-N66U changelog
jlake
If anyone didn't get a chance to make a copy of the old firmware changelog before Asus deleted it-----here it is:
Version 3.0.0.4.370
Description ASUS RT-N66R Firmware Version 3.0.0.4.370
Please note: If you had used the download master windows association tool, please download and install again to pair with latest download master (3.1.0.78)
Fixed:
1. Parental control can now accept special symbol, such as " ' ".
2. 3G/LTE dongle plug into USB port can work without rebooting.
3. Fixed DMZ related issue.
4. Fixed Japan stand time zone issue.
5. Fixed samba/ftp abnormal when length of folder name is too long.
6. Fixed samba/ftp cannot modify account issue.
Added:
1. Added IPv6 DHCP-PD option
2. Added Hungarian and Romanian language
Download master (3.1.0.78)
1. Fixed HDD cannot enter idle mode when there is not download task.
2. Fixed UI related issues.
3. Fixed that some NZB downloading file cannot move to completed folder after download finished.
4. Added HDD config file repaired function to ensure download can be enabled when config file error.
File Size
24,53 (MBytes) 2013.06.11 update
Download from
Global (DLM) Global P2P
Beta Version 3.0.0.4.354
Description ASUS RT-N66R Firmware Version 3.0.0.4.354
Fix
1. Potential security issue from UPnP overflow.
2. Wireless time control related bugs.
3. Media server related issues when lan subnet change or USB hot plug
4. IPv6 over PPPoE interoperability issues.
5. PPPoE password setting error in Advanced wan setting.
6. Wireless MAC filter can now block clients that connect over guest networks.
Modify
1. Upgrade to latest Broadcom driver.
2. Enhance the PPPoE NAT throughput.
3. Enhance both 2.4GHz and 5GHz throughput.
4. Support Huawai E353 3G/4G USB dongle.
5. The router setting URL is changed to http://router.asus.com, use the original URL http://www.asusnetwork.net can also go to the
setting page.
Add
1. Optimize for XBOX option in Advanced Setting-->Wireless-->General. Enable this function can stabilize streaming speed.
2. Network tools in Advanced setting
3. WOL user interface (wake on LAN)
4. H.323 and SIP passthrough can be disabled in Advanced Settings --> WAN -->NAT Passthrough
5. Click the device name and lookup the manufacturer information
6. Change the DHCP query frequency in Advanced settings-->WAN-->Internet connection to resolve the ISP compatibility issue.
Special thanks to Merlin for his contribution.
AiCloud
1. Add deleted button in upload file page.
2. Fixed share link management bugs.
3. Fixed the file and folder rename bugs.
4. Fixed IE9 file upload compatibility issue.
Known issues
1. The router need to reboot after 3G/4G USB dongle setting. It caused longer setting time. If you use the 3G/4G router mode, we recommend staying in 3.0.0.4.270.
File Size
23,99 (MBytes) 2013.03.25 update
Download from
Version 3.0.0.4.270
Description ASUS RT-N66R Firmware Version 3.0.0.4.270
Fixed
1. Parental control time shift issue in GMT-8 time zone
2. Quick internet setting wizard connection issue in iOS platform
3. Quick internet setting wizard login issue when multiple device connect to router at the same time
4. Network place hyperlink issue on IE8 and IE9
5. Live update related bug.
Add
1. Android phone USB Tethering suport. (For more information, please refer to http://support.asus.com/search.aspx?SLanguage=zh-tw&keyword=3G tethering )
2. Select all in parental control
3. Login password strength checker
4. Show lease time at log
5. Add hostname info for who is login
6. YES ISP support in Malaysia
7. More 3G /4G dongles support
File Size
23,69 (MBytes) 2013.01.29 update
Download from
Version 3.0.0.4.260
Description ASUS RT-N66R Firmware Version 3.0.0.4.260
1. Fixed IPTV related issues.
2. Locally administered mac address UI issue in mac filter, parental control, manually assign IP.
3. Upgrade download master to 3.1.0.68
- Enhance UI response time
- Fixed FAT32 related issue
- Fixed the compatibility issue in IE8
- To work with download master 3.1.0.68 the tool must upgrade to DM2_2035
- Please download the tool in the download master help page and install again.
File Size
23,04 (MBytes) 2012.11.07 update
Download from
Version 3.0.0.4.246
Description ASUS RT-N66R Firmware Version 3.0.0.4.246
IMPORTANT, DUE TO THE NVRAM SIZE UPGRADE, CHANGE TO THIS VERSION FIRMWARE (FROM 3.0.0.3.X UPGRADE TO 3.0.0.4.X) WILL WIPE ALL YOUR SETTING!
AFTER UPGRADED FIRMWARE, PLEASE PRESS THE RESET BUTTON AND HOLD OVER 5 SECONDS TO RESET THE ROUTER TO DEFAULT.
Fix:
1. DMZ and HW accelerator coexist issue.
2. Some 3G modem issues
3. Can't reset to default through Software Button when AiCloud is enabled.
4. WPS related issues.
5. VPN dns issue in Android/iOS
6. Buffer overrun problem. Special thanks to Merlin for his contribution.
Modify
1. Add GRO option in Advanced settings->LAN->Switch control.
Please disable it if there are problems in UPnP and port forwarding.
2. Add firmware version checking in Quick Internet Setup process.
3. Add PIN code error alerting for USB modem
4. WPS button can be configured as wifi on/off button
AiCoud (for more information, please refer to http://event.asus.com/2012/nw/aicloud/index.htm)
1. Modify web user interface.
2. Folder is shareable with shared link.
3. The media files can be previewed when received the share link for folder.
4. Redirect mp3 https share link to MP3 player on IOS device.
5. Fixed the large file renaming problem
6. Fixed some UI issues.
File Size
23,03 (MBytes) 2012.10.22 update
Download from
Version 3.0.0.4.176
Description ASUS RT-N66R Firmware version 3.0.0.4.176
The first version of firmware for ASUS RT-N66R
File Size
22,6 (MBytes) 2012.10.22 update
Download from
