RT-N66U: Extension Channel issue
shobhitk
Hi all,
i have been exploring the mighty Dark Knight and came across one minor glitch. if you set the Extension Channel to Lower then it is actually selecting the upper channel and if you set upper, then it selects the lower channel.
for example: if you set 5 as the main channel and set lower as ext. channel insidder shows that channels being used are 5 + 9 :rolleyes:
one more proof of this bug is that if you set 1 as the main channel then the extension channel column has 'Lower' as the only option.
can someone confirm on this pls?
Regards
thanks for the pointer mate...initially i thought that the lower, upper terms are referring to the extension channel....but after reading that article i learned that it was actually referring to the main control channel.
