RT-N66U remote access by ddns
Dr.No.pt
Hello,
Working with new ISP. VODAFONE Fiber. Automatic IP with VLAN 100 tagging.
Latest Merlin build on RT-N66U. ( It was working fine with last ISP with VLAN 10 tagging and PPPoE )
Been using my ddns address to remote access a port forwarded device.
The problem is don't get connection several times a day and logs don' show nothing. No connection drops.
It looks like the connection sleeps and after 1 minute or so it comes back other times i takes like 10 minutes do come back ?
The ip address is the same. It doesn't change.
How can i see/log what is killing (sleeping?) my connection ?
Thank you. :)
I've done a few tests and it looks like the connection only lasts 10 minutes on ? Still no logs.
OK, the problem is NOT solved.
I've made a simpler way to put this:
I've enabled the admin page to be accessible from outside.
When this timeout/freeze is happening even the admin page is not working.
How can i log this ?
RMerlin can you point me to a possible solution ? Normal log doesn't show nothing.
Is there a "Keep alive" option as in PPP0e connection ? (using Automatic DHCP )
Post log entries of the period during which the connection went down then went back up.
RMerlin, the logs don't show anything.
But today this message came up in a grey background color:
"Settings have been updated. Web page will now refresh.
Changes have been made to the IP address or port number. You will now be disconnected from RT-N66U.
To access the settings of RT-N66U, reconnect to the wireless network and use the updated IP address and port number."
Then after some minutes i could get back in as normal but logs don't show nothing. It's like nothing happened.
Could this be a faulty unit ?
Yesterday i was trying other firmwares and sometimes after changing some parameters ( like applying VLAN 100 ) it lost LAN ping connectivity. Had to reflash same firmware or reset it to get connectivity.
I'm getting frustrated with this unit. :rolleyes:
I'm sending you a PM.
Thank you.
Check the router's uptime, you will see if the issue was that the router crashed and rebooted.
Try disabling HW acceleration, under LAN -> Switch. Some ISP's vlan tagging have issues with hardware acceleration. This is something Asus recently started looking at.
Thank you.
I'm sorry, I don't have time to offer one-on-one support.
Here are the logs. It happened same thing at 16:00 (+/-) .
With HW acceleration off it's the same thing.
No crashes or reboot
Dec 27 14:36:24 kernel: ACCEPT  <4>ACCEPT IN=vlan100 OUT= MAC=10:bf:48:d3:78:b0:00:00:00:00:00:30:08:00:45:00:00:34 <1>SRC=89.154.11.140 DST=10.0.0.1 <1>LEN=52 TOS=0x00 PREC=0x00 TTL=121 ID=3228 DF PROTO=TCP <1>SPT=1498 DPT=80 SEQ=477990090 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405B40103030101010402)
Dec 27 14:36:24 kernel: ACCEPT  <4>ACCEPT IN=vlan100 OUT= MAC=10:bf:48:d3:78:b0:00:00:00:00:00:30:08:00:45:00:00:34 <1>SRC=89.154.11.140 DST=10.0.0.1 <1>LEN=52 TOS=0x00 PREC=0x00 TTL=121 ID=3235 DF PROTO=TCP <1>SPT=1499 DPT=80 SEQ=4058166622 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405B40103030101010402)
Dec 27 14:36:25 kernel: DROP <4>DROPIN=vlan100 OUT= MAC=10:bf:48:d3:78:b0:00:00:00:00:00:30:08:00:45:00:00:30 <1>SRC=5.248.10.250 DST=5.249.45.18 <1>LEN=48 TOS=0x00 PREC=0x00 TTL=113 ID=59661 DF PROTO=TCP <1>SPT=2273 DPT=25 SEQ=14642042 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405B401010402)
Dec 27 14:36:27 kernel: ACCEPT  <4>ACCEPT IN=vlan100 OUT= MAC=10:bf:48:d3:78:b0:00:00:00:00:00:30:08:00:45:00:00:34 <1>SRC=89.154.11.140 DST=10.0.0.1 <1>LEN=52 TOS=0x00 PREC=0x00 TTL=121 ID=3244 DF PROTO=TCP <1>SPT=1500 DPT=80 SEQ=963091691 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405B40103030101010402)
Dec 27 14:36:27 kernel: ACCEPT  <4>ACCEPT IN=vlan100 OUT= MAC=10:bf:48:d3:78:b0:00:00:00:00:00:30:08:00:45:00:00:34 <1>SRC=89.154.11.140 DST=10.0.0.1 <1>LEN=52 TOS=0x00 PREC=0x00 TTL=121 ID=3250 DF PROTO=TCP <1>SPT=1501 DPT=80 SEQ=2094485865 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405B40103030101010402)
Dec 27 14:39:30 kernel: DROP <4>DROPIN=vlan100 OUT= MAC=10:bf:48:d3:78:b0:00:00:00:00:00:30:08:00:45:00:00:28 <1>SRC=151.217.68.22 DST=5.249.45.18 <1>LEN=40 TOS=0x00 PREC=0x00 TTL=241 ID=10846 PROTO=TCP <1>SPT=52730 DPT=16992 SEQ=886261036 ACK=0 WINDOW=0 RES=0x00 SYN URGP=0
Dec 27 14:45:21 kernel: DROP <4>DROPIN=vlan100 OUT= MAC=10:bf:48:d3:78:b0:00:00:00:00:00:30:08:00:45:00:00:2c <1>SRC=46.2.220.73 DST=5.249.45.18 <1>LEN=44 TOS=0x00 PREC=0x00 TTL=116 ID=15108 DF PROTO=TCP <1>SPT=1736 DPT=139 SEQ=1002182868 ACK=0 WINDOW=8192 RES=0x00 SYN URGP=0 OPT (0204058C)
Dec 27 14:45:24 kernel: DROP <4>DROPIN=vlan100 OUT= MAC=10:bf:48:d3:78:b0:00:00:00:00:00:30:08:00:45:00:00:2c <1>SRC=46.2.220.73 DST=5.249.45.18 <1>LEN=44 TOS=0x00 PREC=0x00 TTL=116 ID=21765 DF PROTO=TCP <1>SPT=1736 DPT=139 SEQ=1002182868 ACK=0 WINDOW=8192 RES=0x00 SYN URGP=0 OPT (0204058C)
Dec 27 14:45:30 kernel: DROP <4>DROPIN=vlan100 OUT= MAC=10:bf:48:d3:78:b0:00:00:00:00:00:30:08:00:45:00:00:2c <1>SRC=46.2.220.73 DST=5.249.45.18 <1>LEN=44 TOS=0x00 PREC=0x00 TTL=116 ID=35591 DF PROTO=TCP <1>SPT=1736 DPT=139 SEQ=1002182868 ACK=0 WINDOW=8192 RES=0x00 SYN URGP=0 OPT (0204058C)
Dec 27 14:52:20 kernel: DROP <4>DROPIN=vlan100 OUT= MAC=10:bf:48:d3:78:b0:00:00:00:00:00:30:08:00:45:00:00:28 <1>SRC=123.114.67.125 DST=5.249.45.18 <1>LEN=40 TOS=0x00 PREC=0x00 TTL=101 ID=256 PROTO=TCP <1>SPT=5888 DPT=1433 SEQ=827064320 ACK=0 WINDOW=16384 RES=0x00 SYN URGP=0
Dec 27 14:55:16 kernel: DROP <4>DROPIN=vlan100 OUT= MAC=10:bf:48:d3:78:b0:00:00:00:00:00:30:08:00:45:00:00:28 <1>SRC=198.204.236.157 DST=5.249.45.18 <1>LEN=40 TOS=0x00 PREC=0x00 TTL=96 ID=256 PROTO=TCP <1>SPT=6000 DPT=3389 SEQ=1442447360 ACK=0 WINDOW=16384 RES=0x00 SYN URGP=0
Dec 27 15:03:15 kernel: DROP <4>DROPIN=vlan100 OUT= MAC=10:bf:48:d3:78:b0:00:00:00:00:00:30:08:00:45:00:00:28 <1>SRC=80.82.70.156 DST=5.249.45.18 <1>LEN=40 TOS=0x00 PREC=0x00 TTL=236 ID=54321 PROTO=TCP <1>SPT=37254 DPT=8087 SEQ=620096040 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0
Dec 27 15:03:27 kernel: ACCEPT  <4>ACCEPT IN=vlan100 OUT=br0 <1>SRC=89.154.11.140 DST=10.0.0.2 <1>LEN=52 TOS=0x00 PREC=0x00 TTL=120 ID=9480 DF PROTO=TCP <1>SPT=1898 DPT=80 SEQ=163454976 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405B40103030101010402)
Dec 27 15:03:27 kernel: ACCEPT  <4>ACCEPT IN=vlan100 OUT=br0 <1>SRC=89.154.11.140 DST=10.0.0.2 <1>LEN=52 TOS=0x00 PREC=0x00 TTL=120 ID=9481 DF PROTO=TCP <1>SPT=1899 DPT=80 SEQ=504601422 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405B40103030101010402)
Dec 27 15:03:27 kernel: ACCEPT  <4>ACCEPT IN=vlan100 OUT=br0 <1>SRC=89.154.11.140 DST=10.0.0.2 <1>LEN=52 TOS=0x00 PREC=0x00 TTL=120 ID=9483 DF PROTO=TCP <1>SPT=1901 DPT=80 SEQ=2148055137 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405B40103030101010402)
Dec 27 15:03:27 kernel: ACCEPT  <4>ACCEPT IN=vlan100 OUT=br0 <1>SRC=89.154.11.140 DST=10.0.0.2 <1>LEN=52 TOS=0x00 PREC=0x00 TTL=120 ID=9482 DF PROTO=TCP <1>SPT=1900 DPT=80 SEQ=3290250287 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405B40103030101010402)
Dec 27 15:03:27 kernel: ACCEPT  <4>ACCEPT IN=vlan100 OUT=br0 <1>SRC=89.154.11.140 DST=10.0.0.2 <1>LEN=52 TOS=0x00 PREC=0x00 TTL=120 ID=9485 DF PROTO=TCP <1>SPT=1903 DPT=80 SEQ=1891590469 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405B40103030101010402)
Dec 27 15:03:27 kernel: ACCEPT  <4>ACCEPT IN=vlan100 OUT=br0 <1>SRC=89.154.11.140 DST=10.0.0.2 <1>LEN=52 TOS=0x00 PREC=0x00 TTL=120 ID=9484 DF PROTO=TCP <1>SPT=1902 DPT=80 SEQ=2091061528 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405B40103030101010402)
Dec 27 15:03:30 kernel: ACCEPT  <4>ACCEPT IN=vlan100 OUT=br0 <1>SRC=89.154.11.140 DST=10.0.0.2 <1>LEN=52 TOS=0x00 PREC=0x00 TTL=120 ID=9527 DF PROTO=TCP <1>SPT=1898 DPT=80 SEQ=163454976 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405B40103030101010402)
Dec 27 15:03:30 kernel: ACCEPT  <4>ACCEPT IN=vlan100 OUT=br0 <1>SRC=89.154.11.140 DST=10.0.0.2 <1>LEN=52 TOS=0x00 PREC=0x00 TTL=120 ID=9528 DF PROTO=TCP <1>SPT=1899 DPT=80 SEQ=504601422 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405B40103030101010402)
Dec 27 15:03:30 kernel: ACCEPT  <4>ACCEPT IN=vlan100 OUT=br0 <1>SRC=89.154.11.140 DST=10.0.0.2 <1>LEN=52 TOS=0x00 PREC=0x00 TTL=120 ID=9531 DF PROTO=TCP <1>SPT=1901 DPT=80 SEQ=2148055137 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405B40103030101010402)
Dec 27 15:03:39 kernel: DROP <4>DROPIN=vlan100 OUT= MAC=10:bf:48:d3:78:b0:00:00:00:00:00:30:08:00:45:00:00:28 <1>SRC=113.108.21.16 DST=5.249.45.18 <1>LEN=40 TOS=0x00 PREC=0x00 TTL=46 ID=0 DF PROTO=TCP <1>SPT=12213 DPT=1998 SEQ=1227500961 ACK=0 WINDOW=8192 RES=0x00 SYN URGP=0
Dec 27 15:30:32 kernel: DROP <4>DROPIN=vlan100 OUT= MAC=10:bf:48:d3:78:b0:00:00:00:00:00:30:08:00:45:00:00:28 <1>SRC=61.147.116.54 DST=5.249.45.18 <1>LEN=40 TOS=0x00 PREC=0x00 TTL=100 ID=256 PROTO=TCP <1>SPT=6000 DPT=22 SEQ=827064320 ACK=0 WINDOW=16384 RES=0x00 SYN URGP=0
Dec 27 15:31:46 kernel: DROP <4>DROPIN=vlan100 OUT= MAC=10:bf:48:d3:78:b0:00:00:00:00:00:30:08:00:45:00:00:30 <1>SRC=103.23.244.22 DST=5.249.45.18 <1>LEN=48 TOS=0x00 PREC=0x00 TTL=115 ID=42316 PROTO=TCP <1>SPT=12422 DPT=22 SEQ=67186941 ACK=245510612 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405B401010402)
Dec 27 15:33:15 kernel: DROP <4>DROPIN=vlan100 OUT= MAC=10:bf:48:d3:78:b0:00:00:00:00:00:30:08:00:45:00:00:28 <1>SRC=106.35.203.138 DST=5.249.45.18 <1>LEN=40 TOS=0x00 PREC=0x00 TTL=47 ID=64962 DF PROTO=TCP <1>SPT=6868 DPT=3128 SEQ=4194751213 ACK=0 WINDOW=8192 RES=0x00 SYN URGP=0
Dec 27 15:50:43 kernel: DROP <4>DROPIN=vlan100 OUT= MAC=10:bf:48:d3:78:b0:00:00:00:00:00:30:08:00:45:00:01:b0 <1>SRC=50.7.255.18 DST=5.249.45.18 <1>LEN=432 TOS=0x00 PREC=0x00 TTL=50 ID=0 DF PROTO=UDP <1>SPT=5305 DPT=5060 LEN=412
Dec 27 16:01:51 kernel: ACCEPT  <4>ACCEPT IN=vlan100 OUT= MAC=10:bf:48:d3:78:b0:00:00:00:00:00:30:08:00:45:00:00:34 <1>SRC=89.154.11.140 DST=10.0.0.1 <1>LEN=52 TOS=0x00 PREC=0x00 TTL=121 ID=14552 DF PROTO=TCP <1>SPT=2153 DPT=80 SEQ=800624447 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405B40103030101010402)
Dec 27 16:01:51 kernel: ACCEPT  <4>ACCEPT IN=vlan100 OUT= MAC=10:bf:48:d3:78:b0:00:00:00:00:00:30:08:00:45:00:00:34 <1>SRC=89.154.11.140 DST=10.0.0.1 <1>LEN=52 TOS=0x00 PREC=0x00 TTL=121 ID=14554 DF PROTO=TCP <1>SPT=2155 DPT=80 SEQ=3352619628 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405B40103030101010402)
Thank you
All that shows is your firewall blocking connection attempts from the Internet - random port scanning and what not.
Disable logging of dropped packets, it will be much easier to browse through your log.
