RT N66u Router status connected but no internet
ryanpaul
Hi i am having a problem with my Asus RT N66u router. the internet status on the network map says connected and a WAN IP was set. but when i try to connect to any site there is no internet connection
Im using 3.0.0.4.374.38_2 Merlin build and my modem is set to bridge mode.
Router WAN type Automatic IP
Enable WAN Yes
ENable NAT Yes
ENable UPnp Yes
If you need other details you can ask me.
Hope you can help me. thanks!
Try to reboot the router - if that doesn't work, unplug the modem for at least 10 minutes (I leave mine for ~45 minutes unplugged) and then power it up again.
