I've been trying to use the USB Port to attach various USB drives. I've found that they tend to work fine but the N66U will report them as "Not Mounted" if they were reformted. I've tried different drives, removing partitions, reformatting, using different sector sizes but I found that if reformatted in:
- Win8 = Not Mounted error
- Win7 = Mounts just fine
No idea what the difference is or why it should be, but using NTFS and default settings works fine if done from Win7 but not Win8
Go Figure!
Nathan
Go Figure!
Nathan
