RT-N66U VPN config advice
Baz8755
I have the VPN set up on my router and can quite happily access my LAN through it.
However I would like to be able to set up a second connection that will effectively let a device VPN in and only have access to my broadband.
Can anyone advise if and how this is possible
Chreers
Do you mean you have a VPN server setup to connect from the Internet to your home WLAN or the opposite?
You need to setup a VPN client (need to have a VPN provider to connect to) and use policy routing to route on IP (=device) to the VPN.
By the way: Update to the latest Merlin firmware to have VPN updated and fully functional...
Be prepared for anemic speeds because of the limited processing power of the 600Mhz MIPS CPU.
