I am trying to setup a VPN to allow for remote desktop connections and for file sharing and remote backup with my companies main server. I have setup the VPN Server as noted below and I have setup the Client connections. I am able to connect to the VPN and it shows as connects and assigns a Remote IP within the correct Client IP address pool. Once connected, I am able to use internet through the VPN (I do have "Use default gateway on remote network checked on the VPN Client), along with pinging various network computers and the server.
At that point, I am stuck. I am unable to access anything on the network via IP address and I am unable to connect to any network computers via Remote Desktop (I am able to connect to all computers via remove desktop from inside the network).
I am able to connect to the server if using internal IP (192.168...) it I type it in as an FTP address but not direct.
I am using a RT-N66U with Firmware Version 3.0.0.4.374_979
My VPN Clients will be both Windows 7 and Windows 8.1 and some Andriod Devices.
I have setup the RT-N66U VPN Server as follows:
Enable PPTP Server - Yes
Network Place (Samba) Support - Yes
Broadcast Support - Both
Authentication - Auto
MPPE Encryption - MPPE-128, MPPE-40, No Encryption
Connect to DNS Server Automatically - Yes
Connect to WINS Server Automaticlly - Yes
MRU - 1450
MTU - 1450
Client IP Address - 192.168.0.240 ~ 249
My LAN DHCP pool is set for 192.168.0.2 ~ 192.168.0.239
What am I missing or doing wrong? I can post additional info if needed.
Thanks,
Brad
MRU - 1450
MTU - 1450
Thanks,
Brad
