RT-N66U: wireless stability with FW 260 poll
What is your FW stability experience with build 260?
  • 260 and 246 were both stable
    Votes: 13 54.2%
  • 260 is stable, but 246 was not. 220 or 246.19b are stable
    Votes: 5 20.8%
  • 260 and 246 both unstable, 220 or 246.19b are stable
    Votes: 4 16.7%
  • None of these are stable for me.
    Votes: 2 8.3%
  • Total voters
    24
I upgraded to .260 a week or so ago and initially it was running OK. In the last couple of days, I started to run into random disconnect issues in the 5Ghz band. Looks like I might be giving the Merlin FW a try after all. Hate to go through all of the port forwarding set up on the router and have to set it all up again.
You don't need to reconfigure everything if switching to Asuswrt-Merlin. Only in a few cases where you might have corrupted/invalid settings stored in nvram, but try at first without wiping your settings.
I'll give it a try tonight and see what happens. Hopefully everything will come over without issue. If not, I'll screen print the port forwardings I have set up as well as the DHCP reservations.
I just hope that my connection drop issues get fixed, as well as the horrible range issues I'm running into now that I've relocated my router to my basement on one side of the house. Not where I'd like to install it though it's the best option with my current circumstances.
