L ldoffe New Around Here Mar 17, 2016 #1 Has anyone here had a problem registering this router? It's not listed in the dropdown box.
Nullity Very Senior Member Mar 17, 2016 #2 ldoffe said: Has anyone here had a problem registering this router? It's not listed in the dropdown box. Click to expand... Regardless of registration, you still have a manufacturers warranty. Is there an advantage to registering?
pete y testing Very Senior Member Mar 17, 2016 #3 suggest you just reg as the rt-ac66u as they are exactly the same apart from color
