Running a script on a guest network client
m83num
I've got a few of these smart led lightbulbs for the holidays and have them isolated onto a guest network without lan access or internet access... because security.
I'd like to run a script on my AC66 that changes the colors and turns it on and off automagically. How would I go about:
* Getting the IP address automatically
* Installing python and the appropriate library (guess this could be on a usb drive in a virtualenv?)
* Running the script
Alternatively, I can spin up a virtual host that can have the sole purpose of talking to the devices.
* How would I go about putting a vhost on the same network as my smart led bulbs?
1- Getting the IP address automatically
reserve the ip address on your dhcp server, so you dont have to check if it changed every time the script runs.
if you really want to have the trouble, get it with
 ip addr show
and
 grep
or
 awk
2- Installing python and the appropriate library (guess this could be on a usb drive in a virtualenv?)
 opkg install python
3- Running the script
manually?
 sh myscriptname.sh
scheduled?
 cru
Tremendous! Thank you. Any chance you could shed some light on:
* How would I go about putting a vhost on the same network?
One step further is once you've reserved the IP you can use the host name you assign, e.g.
kitchen.myrouter (where you assigned the bulb the host name kitchen and your router is called myrouter). I do this for my Sons CotCam so I can get to it via a browser without remembering the IP. Will make it easier to read the scripts and know which is which should you ever want to differentiate.
