Running Asus routers on battery
chrisisbd
I've tried asking Asus support but just got the "use our power supply or else" type response. All I asked was what are the **actual** power supply requirements for their routers. I.e. what are the maximum and minimum voltages for the router to operate.
I want to run from batteries if I can so need to know if it's safe up to 14.5 volts or so (nominal 12 volt) as batteries on charge can be up to this voltage. If not I can use a 'buck boost' converter that will keep the voltage at 12 volts but this would introduce some power loss which I would prefer to avoid.
