Is there any way to modify the /tmp/etc/smb.conf file and reload Samba configuration using something like 'killall -s SIGHUP smbd'?
The problem is that the firmware overwrites the contents of smb.conf file according to it's own NVRAM configuration and restarts Samba processes just after execution of all provided /jffs/* scripts, causing all changes made from these sсripts to disappear.
Samba restart events are seen in the system log:
Samba Server: smb daemon is stoped
Samba Server: daemon is started
Samba stop (kill) event occurs even if the drive sharing is disabled in the web interface, that makes no sense of running Samba processes from the start scripts.
The workaround is making symlinks for /usr/sbin/smbd and /usr/sbin/nmbd on usb media with renaming them to something like 'smbd3' and 'nmbd3'. After that you can start symlinked files from jffs scripts without fear that they will be killed (as the name of the processes are different now), but there is a little nuance: ASUS firmare turns on 'Generic Receive Offload' feature while starting Samba server. Yes, at the moment it's the cause of some GRO-related crashes, but maybe this will be fixed by ASUS in the future, and using GRO will result in increased network performance. Thus, it would be better if the Samba start and stop operation would be controlled by firmware.
By the way, if the firmware is compiled with GRO support, is it possible to turn this feature (GRO) on and off by a console command?
