EmanuelPSilva
I'm looking for a solution to implement scheduled router backups (Router settings).
My question is: The file I get with the command 'nvram save' is the same I get in the router web page 'Administration/Router settings/Save' (does it have all router info to a eventual restore from factory reset)?
Or instead should I use the 'nvram-save.sh' utility?
NOTE 1: I preferr use use the internal nvram tool as this is automatically updated with the router firmware and is much more faster
NOTE 2: jffs backup is not an issue because I only have to make a tar of dir '/jffs'
Emanuel
Emanuel
