Scammed or not?
CutePaiLon
Hi all, new to the forums with a question I hope someone can help answer.
Just received my "new" Asus AX88U from Amazon and set it all up. Checked the logs and there's a reference to Merlin Support and Firmware installs.
I've scoured the internet and found two replies that seem to fit my situation, neither really seem to be definitive. (https://www.snbforums.com/threads/asus-stock-firmware-with-merlin-logs.81240/) (
To view this content we will need your consent to set third party cookies.
For more detailed information, see our cookies page.
The router was a particularly good price from a third party seller during Prime Day and having seen these references I'm now very suspicious! I wonder if I'm just being paranoid.
May 5 06:05:18 kernel: MerlinSupport::merlin_load_firmware(): end writing firmware to the program ram ...
May 5 06:05:18 kernel: MerlinSupport::merlin16_serdes_init(): Step 6.1 De-assert micro reset
May 5 06:05:18 kernel: MerlinSupport::merlin_wait_uc_active(): wait 50us comclks for micro to be up...
May 5 06:05:18 kernel: MerlinSupport::merlin_wait_uc_active(): Checking uc_active passed ...
May 5 06:05:18 kernel: MerlinSupport::merlin_wait_uc_active(): micro is ready for command ...
May 5 06:05:18 kernel: MerlinSupport::merlin_wait_uc_crc_verify(): micro is ready for command ...
May 5 06:05:18 kernel: MerlinSupport::merlin_wait_uc_crc_verify(): DSC ready for command is not working; SerDes is probably reset!!! reset_state = 7
May 5 06:05:18 kernel: MerlinSupport::merlin_wait_uc_crc_verify(): uCode CRC Verify ...
May 5 06:05:18 kernel: MerlinSupport::merlin_wait_uc_crc_verify(): wait 500us for crc verify to be done ...
Small sample of the log.
I've received so many obviously open box items from Amazon over the years, but this one was shrink wrapped which has thrown me. Given how easy it is to shrink wrap items now though it makes me wonder....
Any help gratefully received!
Thanks for the replies!
It is running on firmware3.0.0.6.102_21514
Colin, I appreciate your answer. Do you have any links that show this definitively by any chance please? You stated in that post that looking around the internet it seems to be a standard message for the AX6000, but I can find no such thing. My Googlefu admittedly is not great!
Thanks again.
RMerlin mentioned this again recently. I'll see if I can find that post.
But the point is that these are not messages generated by Merlin's code. For those of us familiar with Merlin's firmware this is obvious. They are nothing like his messages, they are kernel messages. The source code for Merlin's firmware is available to search and you can see that the messages come from Broadcom's Serdes driver.
2.2 Merlin Core (Management Port)
The following figure illustrates the SerDes block in the device. It is composed of a single quad SerDes PMD blocks
(four lanes) and the supporting digital logic.
Figure 3: Merlin SerDes Core Block Diagram
It is running on firmware 3.0.0.6.102_21514
That is an Asus firmware number. In fact it is the current firmware for the RT-AX88U Pro, not the RT-AX88U.
Merlin doesn't use that numbering convention. Merlin uses something like 388.2_2.
This is the post I was thinking of:
That's what I was hoping to see, thanks Colin. I have never used Merlin before having used my stock ISP router for a number of years so am unfamiliar with custom firmware.
Having scanned the broadcom document I see the Merlin Core references and there are actually a number of references in the code to SerDes also, so that's very reassuring.
The firmware is the latest firmware because I instantly flashed it upon receipt, should have clarified that!
Thanks again.
Appreciated, thank you so much! Just to be clear, I wasn't out to doubt you, I'm just a very demanding Paranoid Android. :)
