Scheduled reboot different to reboot via UI or 'service reboot' ?
alan6854321
Is a scheduled reboot some how different to a reboot via other means. e.g. via the UI or 'service reboot' command?
I decided to setup the reboot scheduler a few weeks ago, so I've gone through 3 of them now (Early Sunday mornings).
On each occasion, there were odd problems that a 'normal' reboot via the UI fixed.
On one occasion, the 5G network slowly ground to a halt, after around 24 hours clients could connect to it, but throughput was incredibly slow.
This morning, I had 'restart_letsencrypt' entries in syslog every 5 minutes (I posted another thread about it), also I noticed that the red 'internet' light was on the router and the UI said 'WAN Disconnected' (It wasn't - everything was working fine).
Restart internet connection, web interface and DDNS client from the scMerlin page made no difference, but a reboot from the UI did.
Any idea what might be going on?
I've switched off the reboot schedule for now, seems to do more harm than good.
I have no idea if there is a substantial difference (I doubt it), but if you're satisfied w/ the results of using the 'service reboot' command, it's easy enough to create your own cronjob.
cru a reboot "0 6 * * * /sbin/service 'reboot'" # reboot everyday @ 6:00 AM
You would need to make it persistent using a services-start script.
Yeah, I already had that as a 'cunning plan'.
But, it'd be nice to know why the "scheduled reboot" system doesn't produce the same result. I mean, they really should be the same.
