Scheduled reboot
issom beituni
I got an AX11000 and a node set up with AIMesh
When it’s a scheduled reboot in the software does the main router just reboot or both?
To enable the built-in scheduler, SSH to the nodes and run these commands (adjust the days/time to your preference):
nvram set reboot_schedule_enable=1
nvram set reboot_schedule=10000000215
nvram commit
reboot
NOTE: The above sets this for sunday at 2:15am. The day of the week is set to 0 or 1 to enable them, beginning with Sunday. If you wanted Mondays at 2:15pm, the value would be 01000001415
I also find that after the first reboot of the node, that it will reset itself to the same day & time as the mesh router if it is set.
nvram commit
reboot
can i do this reboot_schedule ONY on a specific node?
because if i setup this , i do an nvram commit, reboot => then i wait for the time, but it doesnt reboot at all ?
is it possible , because the scheduler on the main router is not enabled? and when the node is rebooted, it will be not enabled as well?
is there a command in ssh, to actually see the status of the reboot scheduler? if its enabled or not?
I've had my AX6600 / XT8 for only about 10 days. it has gone through only one weekly scheduled reboot. and they both did. the router and the node. No special setup.
