SCP/Dropbear known_hosts authorization in starting scripts on RT-AC68U 384.12
zperetz
Hi everyone,
I have some scripts that uploaded some important files to the cloud on router's restart. Of course I had known_hosts that were uploaded to ~/.ssh/ and had no requests for trusted hosts for automation process.
But starting from 384.12 I started getting errors of upload.
Copying to ~/.ssh gives an error of read-only file system, if it's done in starting scripts. Going to deeper debuging I've found out, that even if I copy directly to /home/root/.ssh/, I still getting the following error for scp command in starting script (it's important, that it's called from the scripts)
--- script.sh---
scp -i id_rsa -P 2222 /tmp/log.log [email protected]:~
/usr/bin/dbclient: Warning: failed creating //.ssh: Read-only file system
Host 'upload.local' is not in the trusted hosts file.
Which looks like Dropbear is also trying to write to ~/.ssh/know_hosts with no luck.
But if I repeat the same scp action from CLI (after logging in), the problem disappears, and known_hosts is accepted, which means that ~ direction is recognized.
Any idea of solution is very appreciated.
It looks like dropbear thinks your home dir is / instead of /root, which would lead to the read-only filesystem error. Which start script are you using to run your script? Maybe it’s too early in the boot process.
Try setting $HOME=/root in your script.
I'm using firewall-start to call, and tried to use some timeouts, it was not helping. But setting HOME to /root was a good idea, thanks it helped.
matthew_eli No dropbear on system log Asuswrt-Merlin 7
