[script] GT-AX11000 IP Changer.
Rajjco
Hello there. Made a script that changes your wan ip address with a single click. I'm just too lazy to login to router whenever I want a new ip.
just wanted to share it with people who are lazy like me and there's nothing wrong with that.
Requirements:
1.Asuswrt-Merlin Firmware.
2.Dynamic IP address from ISP.
Notice:
Might work on different AX models if they share the same html templates.(try it out)
Download:
https://github.com/Rajjco/ROG_Raptu...ases/download/v1.0/AX11000_IP_Changer_x64.zip
ColinTaylor
Part of the Furniture
Am I correct in thinking that what this script does is log into the GUI (via http), disable the WAN and then re-enable it?
That typically doesn't work for cable connections but might for dialup connections.
P.S. Thanks for the contribution. But with all due respect I'm not running binary code from someone that's never posted here before and only setup their github page a month ago. I appreciate that the source code of the python script is here though.
Rajjco
Yes. That's what it actually does. It works fine for PPOE connections.
You can always grab the source code and run it for yourself. I did compile it to standalone exe for people that don't want to install dependencies and install python on their machines.
