Script Question
drinkingbird
Part of the Furniture
I've got a script running at services-start to do some vlan configs.
If I make changes to certain things, it often gets overwritten requiring a reload or manual run of the script.
I'm looking at running the same script against service-event-end for a few different services to see if that reapplies the configs automatically whenever that event happens
But I'm not clear on how to pass the two required arguments to the script - normally if running it by hand you simply specify them after the command, but if these are supposed to be automated, are the arguments put in the script?
I'm probably not understanding this particular script, maybe it has to be called from another script or something....
Thx
dave14305
The firmware calls service-event-end with the two parameters after it has finished processing the original command. You wouldn’t run the script manually or from any other script.
drinkingbird
So how do I tell it to run on say wireless restart? Or does it just run on every service event?
dave14305
It runs on every event and you have to check $2 = wireless for example. Put an empty service-event-end script in place and watch the syslog to observe which parameters get passed.
drinkingbird
Well, the script I have doesn't hurt anything if it gets run again (just overwrites what is there), so I guess that may be what I'm looking for. Just need to look at what kind and how many of service events there are, don't want it running every time someone gets a DHCP IP or joins/leaves the wifi.....
drinkingbird
So I could either just let it run after every service event which is probably excessive, or use "if" or whatever type of filter to only look for things like restart wireless, restart firewall, etc. Think I get it now.
dave14305
Under normal steady operation, you won’t see many service events. During boot up, it could be a lot.
