Script That Would Reboot AImesh Units via Cron?
Elmer
Is there, or would it be possible to make, a script that would auto reboot aimesh units?
If you are running Merlin firmware on primary router and AiMesh node, it should be as simple as creating a cron job with the reboot CLi command within one of the scripts within /jffs/scripts that runs after AiMesh node boot. For example, reboot at one (1) minute after midnight daily:
cru a 1 0 * * * reboot
